FTDX-10 CAT problem
Posted: 22 Sep 2021, 14:28
by PD0JVB
hi all ,
i have connected my FTDX-10 with my pc and downloaded the latest omnirig , set the port at com7 but the frequentie stays offline
what am i doing wrong ?
Re: FTDX-10 CAT problem
Posted: 22 Sep 2021, 20:06
Latest Omnirig being what version number?
Posted: 23 Sep 2021, 13:45
by PD0JVB
G4POP wrote: 22 Sep 2021, 20:06 Latest Omnirig being what version number?
hi Terry , omnirig 1.20
Posted: 23 Sep 2021, 14:02
by DF5WW
Have you set the correct baud rate ? Check the transceiver menu (manual) for the COM settings and
check how your COM7 is set to and Omnirig. All must have the same baud rate. Looks that 1.20 is the
latest original from Afreet Software and should be run but i can´t test so my both transceivers can´t
longer handle CAT after a lightning flash a few weeks ago.
