I would like to report minor UX issues/possible UX improvements:
- during QSO logging when using a tab key to switch between inputs, tab key should skip "start/end" time inputs when they are locked, e.g. in that case tab index should continue direct to "operator name" input after S/R inputs.
It is a bit annoying in case of pile-up to push tab twice to skip time which is already filled-up automatically
- with tab input switching it will be helpful to have some "red frame" around focused input (like in callsign input) for better visibility on which input we currently are
Suggestion - tab index behavior
Re: Suggestion - tab index behavior
This is not an error report it's a feature suggestion so moved to correct forum area
Thanks Terry, next time I will better check before send. Thanks for moving to correct forum area.
73 es GL
73 es GL
