Importing from N3FJP
W4GHV
Post by W4GHV »
Trying to transition from N3FJP logger, I got tons of errors during import.
Where is the error log located so I can insure all QSOs imported?
I'm considering using the portable version so it can be used with 2 computers.
The youTubes have been great¡
73, Bo W4GHV since '54
https://www.qrz.com/db/W4GHV
Re: Importing from N3FJP
You dont need the portable version if you want to install on two computers only if you are wanting to run Log4OM on someone elses PC like the club or workplace PC
The import log can be saved as a text file from the import screen, its not saved routinely
W4GHV
Post by W4GHV »
Thanks for the tip. It should be easy to match the settings on 2 PCs. Now to set up a sharable location for the log file.
I wanted to log at the log file to see what all the errors were about. I clicked save log but can't find it.
Many thanks.
Bo W4GHV
When you click save log I thought it asked you for a location?
W4GHV
Post by W4GHV »
Yep. Where is the file located on my PC?
