Page 1 of 2
Unable to delete Propagation Mode
Posted: 29 Oct 2021, 13:26
by F4VWD
Using version 2.15.0.0.
I inadvertently left 'SATELLITE MODE' checked on the 'My (F4)' tab after a couple of QSO's on QO-100.
I can edit the QSO to clear the satellite name and mode but I'm unable to delete the Propagation Mode which displays 'Satellite'.
Is there any chance that a blank entry is available in the drop down list to correct the Prop Mode?
Cheers,
Andy
Re: Unable to delete Propagation Mode
Posted: 29 Oct 2021, 14:59
Why not delete it in the QSO manager?
Why are you using an old version?
Posted: 30 Oct 2021, 00:48
by F4VWD
G4POP wrote: 29 Oct 2021, 14:59 Why not delete it in the QSO manager?
Tried that as well, I can't do it there either.
G4POP wrote: 29 Oct 2021, 14:59 Why are you using an old version?
Because I was unaware of a newer version.
Posted: 30 Oct 2021, 01:15
by KI5IO
[/quote]
You must be overlooking the notification button (yellow triangle or blue circle) that provides you with notifications each time you turn on Log4OM V2. A left click on the button will provide you with information about a new release or other d/b updates.
Not sure how you have been missing this.
Posted: 30 Oct 2021, 08:41
Really?
Posted: 31 Oct 2021, 22:24
by F4VWD
OK, I'm able to edit the QSO in the QSO Manager so that works as expected, not sure what I was referring to earlier.
In the 'Recent QSO's' tab clicking on a QSO brings up an 'Edit QSO' box, maybe my interpretation of the word 'Edit' is slightly different to others... ;)
Cheers,
Andy
Posted: 01 Nov 2021, 12:17
added "blank" valuee to SATELLITE MODE dropdown list in EDIT QSO screen
Posted: 02 Nov 2021, 17:16
by F4VWD
IW3HMH wrote: 01 Nov 2021, 12:17 added "blank" valuee to SATELLITE MODE dropdown list in EDIT QSO screen
That's it! Simples...
Grazie!
Posted: 06 May 2022, 10:03
by F4VWD
That 'blank value' appears to have disappeared in v2.21.1.0
Posted: 06 May 2022, 10:28
by KI5IO
EI8KF wrote: 06 May 2022, 10:03 That 'blank value' appears to have disappeared in v2.21.1.0
Download the most current Beta release ... https://www.log4om.com/download/
