CAT control, networked 7300 on hamlib stopped working
Posted: 30 Oct 2021, 17:36
by k9wbt
Hello everyone.
I searched and searched the forum and I can't seem to get the answer I need.
I had CAT control working remotely to my IC 7300 for months. Last night while logging for CQWW, it just stopped working. I have tried every setting possible, restored backup config.json, turned off firewalls on both my laptop that I am remoting from and also on the desktop connected to my rig. Rebooted both machines and my network equipment. Reinstalled both hamblib for Windows 10 and Log4OM. Log4OM works on the desktop the rig is connected to. Also, I use WFview on the laptop and it works over the network. I'm stumped and I have spent hours now on it.
I found this of note in the log:
2021-10-30 17:30:16.0619 INFO: [#=zzwZPo6w=] : [HAMLIB] Hamlib Process exit code: 2
2021-10-30 17:30:16.0640 INFO: [#=zzwZPo6w=] : [HAMLIB] DAEMON STOPPED. Hamlib instance terminated
2021-10-30 17:30:16.9692 ERROR: [HamlibEngine][#=zBU5f$TgHmV4VgKG3PLLUL6I=] : [EXCEPTION] No connection could be made because the target machine actively refused it
Thank you in advance for your help.
~K9WBT
Re: CAT control, networked 7300 on hamlib stopped working
Posted: 30 Oct 2021, 17:53
by k9wbt
**UPDATE--FIXED**
Somehow, unrealted to Log4OM, "enable RigCtld" got unchecked in my WFview settings. Once I checked it again, CAT now properly connected to the port.
Thank you.
