Page 1 of 2
IOTA Reference?
Posted: 13 Dec 2021, 18:16
by PA7RA
I am working on my IOTA score and now I have filtered my LOG4OM with award Filter and then AF.
then I should get all Iotas that are in AF I thought.
What is my surprise
see the screenshot I sent along with this message.
I circled it in red
AN AS and an AN now the question is how can I change these when it comes to VK0EK and 8Q7LA have I done something wrong or is this a bug in LOG4OM?
Thanks for the help
regards
Rien, PA7RA
Re: IOTA Reference?
Posted: 13 Dec 2021, 19:09
Not saying it's not a bug but most times it's an entry error
Open the qso and check the awards tab details
Re: IOTA Reference?
Posted: 13 Dec 2021, 19:51
by PA7RA
I made a screenshot of the award tab
and there it says WAC@AF
I think that's the problem, but how can I change it?
thanks for the quick response i'm learning more and more about this great software.
Rien, PA7RA
Re: IOTA Reference?
Posted: 13 Dec 2021, 20:35
Delete to existing AF reference and then allocate the correct reference - Save and apply
Re: IOTA Reference?
Posted: 14 Dec 2021, 16:19
by PA7RA
Hi Terry.
I'm trying to change the continent but LOG4OM still sets 8Q7LA back to continent AF!
What am I doing wrong?
I'll do it step by step so maybe you can see where I'm going wrong?
1. Awards Refs.
2. click on WAC@AF and on the minus sign to delete.
3.add UNLISTEND reference
4. Reference CODE I type AS and click on the checkmark
5 WAC@AS is now in the list!
6 I click on Save and exit.
When I open the qso again and then look in Award Refence it says WAC@AF again and also WAC@AS
I hope it's a bit clear but I can't get this right
Thank you Greeting
Rien, PA7RA
Re: IOTA Reference?
Posted: 14 Dec 2021, 16:31
by KI5IO
Rien,
Try same steps again, but also ADD a tap on the little diskette symbol to save and then tap the Green Checkmark to save overall.
Re: IOTA Reference?
Posted: 14 Dec 2021, 17:18
Also in the Award statistics window go to the maintenance tab and rebuild the statistics
Re: IOTA Reference?
Posted: 14 Dec 2021, 18:36
by PA7RA
Thanks for the tips unfortunately none of them work VK0EK just stays on AF as a continent
Don't understand what's going wrong.
I deleted the qso and manually re-entered it in LOG4OM but LOG4OM grabs WAC@AF directly instead of WAC@AN
8Q7LA has disappeared from the list, but I don't know how this happened.
Re: IOTA Reference?
Posted: 14 Dec 2021, 20:17
I am so confused about this
The heading says an issue with IOTA but you keep displaying a Worked all continents award
You first refer to 8Q7LA which is IOTA@AS-013 the Maldives and then you change to VK0EK which is Heard Island IOTA@AN-003 but your still refering to the Worked all Continents award, not IOTA?
Explain again please because after 25 yours of producing software I am realy confused!
I have both those calls correctly displayed in IOTA see below
Re: IOTA Reference?
Posted: 15 Dec 2021, 17:15
by PA7RA
Hello Terry,
I have read your explanation again and followed it step by step and now it is all right thanks for your patience and help with this
Sincerely
Rien PA7RA
