Tonight I made my first QSOs on 60m. I auto uploaded them from WSJT-X. When I go to edit the QSO to send QSLs I get the same error message others have received. I had already changed my preferences to include the 60m band. It appears that the band and band rx slots in the contact information menu have been dropped and are blank. If I change them manually on every QSO it allows me to edit the QSO, but it is a real pain in the neck to do every time. Is there a way to set a default like the other bands have? I have tried to edit this on 2 PCs. It will not permit me to.
Rob
WR3Y
Can not edit 60m QSOs
Re: Can not edit 60m QSOs
What Log4OM version number are you usingWR3Y wrote: 30 Dec 2021, 23:35 Tonight I made my first QSOs on 60m. I auto uploaded them from WSJT-X. When I go to edit the QSO to send QSLs I get the same error message others have received. I had already changed my preferences to include the 60m band. It appears that the band and band rx slots in the contact information menu have been dropped and are blank. If I change them manually on every QSO it allows me to edit the QSO, but it is a real pain in the neck to do every time. Is there a way to set a default like the other bands have? I have tried to edit this on 2 PCs. It will not permit me to.
Rob
WR3Y
Is 60m in the band list of the program config?
60m shows up in my band drop down and checked off in the band preferences. I am using 2.18.0.0
When I manually save a QSO I have 60m set in the drop down, but when it saves it. It shows up as 15m . If it is saved from WSJT-x it saves properly, but I can't edit it without manually putting 60m band and 60M in band RX which are then both blank.
I don't know use CAT. All my Qs are remote. No radio connected.
Please explain your set up with WSJT and exactly how your working remote
If your available on skype I am free now?
