QSL view not populated in 2.20
Posted: 21 Feb 2022, 16:50
by ac5aa
Hello - first, thanks for keeping the improvements coming - what a great support team! Now, I installed 2.20 last night before importing my ARRL DX CW log. All seemed to go well, and then I uploaded the new Q's to LoTW. All went well except the log field in the QSL Manager window would not populate with the logging status. It remains completely blank. If I tap the "Search" tab at the top, I see the red "Refreshing" flag at the bottom of the window, but it still shows 0 of 5000 selected. In the past, searching an empty callsign entry displayed the status of the last 5000 Q's but now it shows empty. Have I done something wrong? Is there a way to see this that I've missed? Thanks in advance!
73, Duane
Re: QSL view not populated in 2.20
Posted: 21 Feb 2022, 17:17
by ac5aa
More info - I just noticed that in the "QSL" (as opposed to LoTW) view, only QSO's up to 1/29/2020 are displayed, nothing after that. Peculiar....
73, Duane
Posted: 21 Feb 2022, 22:22
Change requested to sent
Posted: 21 Feb 2022, 23:00
by NN7D
Duane,
Or remove the Sent filter criteria - set it to blank. Then you should see all of your QSO's, or at least the latest X number.
Posted: 22 Feb 2022, 19:49
by ac5aa
Thanks, Terry and Doug - stupid user error. I never use the "sent" field, but for some reason after 2.20 loaded it was set to "Sent" - and I didn't notice. Setting it to blank (no parameter) fixed it. Whew! Knew it had to be something easy . . .
73, Duane
Posted: 22 Feb 2022, 23:33
by NN7D
Glad it was something simple. Glad to help!
Posted: 23 Feb 2022, 13:59
by WB4IT
ac5aa wrote: 22 Feb 2022, 19:49 Thanks, Terry and Doug - stupid user error. I never use the "sent" field, but for some reason after 2.20 loaded it was set to "Sent" - and I didn't notice. Setting it to blank (no parameter) fixed it. Whew! Knew it had to be something easy . . .
73, Duane
Slightly off-topic, but do you use N1MM in contests like ARRL DX CW? If so, you should look into the UDP integration between N1MM and Log4OM for sending contacts from N1MM to Log4OM automatically. Page 211 in the user manual.
I've been using it the past couple of weeks and it's great.
