Label print - missing QSL manager
IK4OMU
Post by IK4OMU »
I'm using the 2.20.0.0 version of the software.
When I select one (or more) logged QSO, for printing label, which has the "Qsl via" field filled
I'm expecting to find the data in the field "QSL Via" in the following step instead of find it empty
Am I doing something wrong?
73 - Maurizio IK4OMU
Re: Label print - missing QSL manager
Dont know where you did your lookup but that call sign shows 'Via Bureau or Direct' and is displayed in te QSL via box OK here
IK4OMU
Post by IK4OMU »
G4POP wrote: 21 Mar 2022, 20:35 Dont know where you did your lookup...
I filled the "Qsl via" data before saving the QSO into the log, adding that information to those of QRZ.com lookup.
IK4OMU wrote: 21 Mar 2022, 21:21
OK got it the manual entry is not being used
Thanks for spotting
QSL via is a field that is filled by QRZ and/or user, and it's updated by default from Log4OM.
actually there's no way to identify an user written information vs externally retrieved info, so by default the field is cleared and refreshed with new data.
I must think how i can identify user data from automatically filled data
DK9JC
Post by DK9JC »
Interesting post. I also discovered this "issue". I often add the manager manually and wondered in the same field why it was empty. I think any manual entry should override any external sources. Often the guy on the other ends says "QSL via XX" or something like that, where online resources are often outdated.
https://www.dk9jc.de
