Lotw help
KB1FGC
Lotw help
Post by KB1FGC »
Hi,I can't seem to load my QSO up to LOTW.I select then in QSL manager and when I load the selected qso's it says LOTW END.Thanks in advance.
Thanks Rich
73 KB1FGC
Re: Lotw help
KB1FGC wrote: 08 Apr 2022, 02:18 Hi,I can't seem to load my QSO up to LOTW.I select then in QSL manager and when I load the selected qso's it says LOTW END.Thanks in advance.
Rich,
I had a similar occurrence yesterday with LoTW as well. Not sure what happened, but when I stopped/cancelled the procedure and then shut down L4OM I had a small window on my screen indicating some error message related to TQSL.
I opened up the Windows Task Manager saw some TQSL process was still running. I ended that process, restarted L4OM and did my LoTW upload (all of 3 Q's) manually and it worked FB.
Just do a view of processes via your Task Manager and see if you might have similar.
KB1FGC
Re: Lotw help
Post by KB1FGC »
Nolan--Thanks alot! it worked.My task manager wouldn't open.If my computer is on several days and a program is open the sometimes the computers acts odd.In this case I had an issue with Log4OM.I did a restart.Thanks and will keep that in mind in the future
vy 73
Thanks Rich
73 KB1FGC
