QSO not Saved. Check Band/Mode/Callsign/Date Error
Posted: 10 Apr 2022, 01:04
I just started using Log4OM and I REALLY like it so far. When I edit a QSO is seems to forget the Band and Rx Band of the QSO and won't let me save the edits until I reenter the Band info. For example in the attached screenshot I edited the QSO and added "Test notes!" to the note filed. When I went to save it I got the error in red "QSO not saved. Check Band/Mode/Callsign/Date". I then had to add the Band and Rx Band back in before I could save it. This happens every time I edit a QSO. Is this a bug or am I doing something wrong? Thank you.
![Image]()
