PSTRotator control
Posted: 17 Apr 2022, 13:17
by w9mdb
I'd like to be able to send a control message via the control port to trigger Log4OM to send the azimuth to PSTRotator.
I have an external utility that controls my antennas and when the hex beam is selected I'd like to have the antenna automatically rotate to the azimuth in Log4OM.
I can watch for the call sign change and then send the command.
Re: PSTRotator control
Posted: 18 Apr 2022, 08:13
by N1FG
Doesn't it already work that way with PSTRotator - it does for me.
When I put the callsign into the window and let Log4OM get the details filled in, I simply look at the Azimuth window (to the right of the frequency readouts) and press either the short path or long path heading and the command is sent to PSTRotator.
If I have misunderstood your question I apologize, but it's a feature I use every contact on 40m thru 6m.
Larry
- Log4OM.JPG (239.63 KiB) Viewed 2694 times
Posted: 18 Apr 2022, 15:15
by w9mdb
Yes...I can click on the azimuth in Log4OM...but I'd like to be able to be able to automatically point my beam when the beam is in use.
My antenna controller program knows which antenna is in use and could send a move command to Log4OM to send the azimuth over. What my program does not know is the azimuth so that's why using Log4OM's existing capability to do this would be better.
Posted: 19 Apr 2022, 08:44
by N1FG
Oh, I see. What program is filling in the callsign information? (Does it know whether Short or Long path is better?)
Posted: 19 Apr 2022, 09:09
by CT1BXX
N1FG wrote: 19 Apr 2022, 08:44
... (Does it know whether Short or Long path is better?)
Larry,
As far as I know the information (Short vs Long path) only here:
https://www.voacap.com/hf/
In Log4OM we only have prediction for Short path !
Posted: 19 Apr 2022, 09:17
by N1FG
GM Manuel,
Thanks for the link. I have wondered about the LP prop (and normally use VOACAP directly for that) but often I will just spend some time and swing the antenna but wish it was quicker with Log4OM!
Often at this time of the day my friends in VK are talking with EU and I will get a good opportunity to try both paths with them.
73, de Larry N1FG
Posted: 19 Apr 2022, 13:10
by w9mdb
I'm referring to the remote control messages which right now purportedly has just 3 commands available
<CALLSIGN>
<WORKED>
<WORKED+BAND>
I'd like to see
<ANTENNA+MOVE>azimuth
Posted: 19 Apr 2022, 17:24
by N1FG
I'm sorry to have said anything, I had misunderstood your posting from the beginning.
Good luck!
73 de Larry N1FG
