Winkeyer not recognised
Posted: 17 May 2022, 13:02
by G3UGK
I'm sure this is very basic but it's got me completely befuddled:
I have a Digimaster from ZLP Electronics which works fine on my desktop PC with Log4OM so I know there's nothing wrong with it. However, I have a new laptop running Windows 10 running Log4OM perfectly except that it will not recognise the Digimaster. The computer has allocated a COM port for it and all the parameters seem correct - baud rate etc. However when I open the Keyer window the notification at the bottom for keyer engine is 'Nothing'. I would expect it to say 'Winkeyer', as it does on my big PC.
HELP...
Phil G3UGK
Re: Winkeyer not recognised
Posted: 17 May 2022, 14:15
by G3UGK
Further. I found the setting in the Program Configuration file and selected Winkeyer. (Never had to do that before, so I plead mitigation.) Now I can connect Winkeyer, and it all looks good. Problem is it doesn't actually work, either on tune, or direct type or a macro. There must be something I'm missing, so would appreciate some advice on where to look next. Thanks
Phil
Posted: 17 May 2022, 17:21
by KI5IO
Phil,
Posted: 17 May 2022, 18:49
by G3UGK
Hi Nolan
I'm using the latest version Log4om 2 next gen
Phil
Posted: 17 May 2022, 20:55
G3UGK wrote: 17 May 2022, 18:49
Hi Nolan
Phil
Please the actual release number!
Posted: 18 May 2022, 08:03
by G3UGK
Hi Terry.
Version is 2.21.1.0
There's been some progress:
Now what happens is that Winkeyer connects properly, and when I type some text and press the Tx button, I can see the program responding inasmuch as the characters one by one turn grey as they are "transmitted". The only thing that's not happening is that the 7300 is not going into transmit mode. I tried putting the 7300 into tx mode manually, but still nothing was transmitted. So it seems that everything is working except that - in very non-technical terms - the transmitted text is not actually finding its way to the radio. I also tried the alternative '7300 Data' set in Omnirig, but no luck.
Phil
G3UGK
Posted: 18 May 2022, 08:31
And is the 7300 in CW break in mode and is it configured for a straight key, not a keyer
Posted: 18 May 2022, 09:31
by G3UGK
Yes and yes
Phil
Posted: 18 May 2022, 10:23
by G3UGK
Sometimes one can get so bogged down in detail that the basics get forgotten. In this case I blame the dog, which is not allowed in the shack, but sneaked in when I wasn't looking a couple of days ago. She'd managed to partly disconnect the Digimaster lead from the rear of the radio. I plugged in back in properly and now all is well.
So apologies to all.
Lesson learned
Phil
