Page 1 of 2
Log4OM hangs when sending QSOs to LOTW
Posted: 23 May 2022, 20:56
by oo7f
Hi
When shutting down Log4OM it hangs after uploading to LOTW
Version
Log4OM Next Generation (V2) version: 2.22.0.0
Log
2022-05-23 19:57:42.8650 INFO: [#=zWALfnFpbUKNS0c3DmuABWMb5hotH] : ##################### USER REQUESTED APPLICATION SHUTDOWN #####################
2022-05-23 19:57:42.9875 INFO: [SplashScreen] : Shutting down Log4OM application
2022-05-23 19:57:42.9885 INFO: [#=z4AY3q02MJFClfStrjg==] : Shutting down Log4OM application
2022-05-23 19:57:42.9903 INFO: [SplashScreen] : Saving form status...
2022-05-23 19:57:42.9913 INFO: [SplashScreen] : Uploading LOTW data (120 seconds timeout)
2022-05-23 19:57:42.9953 INFO: [#=z4AY3q02MJFClfStrjg==] : Running LOTW Auto Upload
2022-05-23 19:57:42.9968 INFO: [LOTWManagement] : [LOTW] Searching QSO in No status for upload to LOTW...
2022-05-23 19:57:45.1283 INFO: [LOTWManagement] : [LOTW] Found 10307 QSO. Uploading...
2022-05-23 19:57:45.1283 INFO: [LOTWManagement] : [LOTW UPLOAD] uploading LOG with 10307 QSO
2022-05-23 19:57:45.1380 INFO: [AdifManagement] : Begin export to ADIF file: C:\Temp\LOTW_UPLOAD_20220523195745.adi
2022-05-23 19:57:46.2138 INFO: * [AdifManagement][1074 ms] : Export to ADIF file completed: 10307 QSO
2022-05-23 19:57:46.2148 INFO: [LOTWManagement] : [LOTW UPLOAD] TQSL Version 2.6.2
2022-05-23 19:57:46.2148 INFO: [LOTWManagement] : [LOTW UPLOAD] No private TQSL Password set
2022-05-23 19:57:46.2160 INFO: [LOTWManagement] : [LOTW UPLOAD] Executing TQSL with upload. Parameters: C:\Program Files (x86)\TrustedQSL\tqsl.exe
2022-05-23 19:57:46.2160 INFO: [LOTWManagement] : LOTW MANAGED MODE
Thx 73's
Kurt
Re: Log4OM hangs when sending QSOs to LOTW
Posted: 23 May 2022, 21:19
Your trying to upload over 10,000 qso's that will take some considerable time, like probably hours
Why are you uploading so many?
Posted: 23 May 2022, 21:24
by oo7f
I first imported the ADIF file manually in LOTW.
Can I manually change the field of LOTW to YES for all previous QSO's?
Regards,
Kurt
Posted: 24 May 2022, 06:45
Of course! by using the QSL manager you can bulk edit the confirmation fields
Try reading our extensive user guide or watch the three Youtube tutorials regarding 'Confirmations'
Posted: 24 May 2022, 17:22
by oo7f
found it
Regards,
Kurt
Posted: 24 May 2022, 18:15
by oo7f
By the way ... cool ending in the log file
2022-05-24 18:13:46.5528 INFO: [#=zJRT2wG9ZoLh2186ezQ==] : 73 see you soon...
Posted: 25 May 2022, 07:06
by oo7f
Sorry to bump this thread up.
After closing the program and successfully upload to LOTW and then open the LOG4OM program the QSO's are not set to YES in the sent field for LOTW.
Or do I need to do this every time manually?
Regards,
Kurt
Posted: 25 May 2022, 07:21
Should mark them automatically check the logfile to see what happened
Posted: 25 May 2022, 07:57
by oo7f
It works now
It is like at the office, people call me with a problem, once I arrive it is magically fixed
For information;
Code: Select all
2022-05-25 07:54:51.6938 INFO: [#=zWALfnFpbUKNS0c3DmuABWMb5hotH] : ##################### USER REQUESTED APPLICATION SHUTDOWN #####################
2022-05-25 07:54:51.8344 INFO: [SplashScreen] : Shutting down Log4OM application
2022-05-25 07:54:51.8344 INFO: [#=z4AY3q02MJFClfStrjg==] : Shutting down Log4OM application
2022-05-25 07:54:51.8344 INFO: [SplashScreen] : Saving form status...
2022-05-25 07:54:51.8500 INFO: [SplashScreen] : Uploading LOTW data (120 seconds timeout)
2022-05-25 07:54:51.8500 INFO: [#=z4AY3q02MJFClfStrjg==] : Running LOTW Auto Upload
2022-05-25 07:54:51.8500 INFO: [LOTWManagement] : [LOTW] Searching QSO in No status for upload to LOTW...
2022-05-25 07:54:53.6308 INFO: [LOTWManagement] : [LOTW] Found 25 QSO. Uploading...
2022-05-25 07:54:53.6466 INFO: [LOTWManagement] : [LOTW UPLOAD] uploading LOG with 25 QSO
2022-05-25 07:54:53.6466 INFO: [AdifManagement] : Begin export to ADIF file: C:\Temp\LOTW_UPLOAD_20220525075453.adi
2022-05-25 07:54:53.6621 INFO: * [AdifManagement][15 ms] : Export to ADIF file completed: 25 QSO
2022-05-25 07:54:53.7089 INFO: [LOTWManagement] : [LOTW UPLOAD] TQSL Version 2.6.2
2022-05-25 07:54:53.7089 INFO: [LOTWManagement] : [LOTW UPLOAD] No private TQSL Password set
2022-05-25 07:54:53.7089 INFO: [LOTWManagement] : [LOTW UPLOAD] Executing TQSL with upload. Parameters: C:\Program Files (x86)\TrustedQSL\tqsl.exe
2022-05-25 07:54:53.7089 INFO: [LOTWManagement] : LOTW MANAGED MODE
2022-05-25 07:54:55.8647 INFO: [LOTWManagement] : [LOTW UPLOAD] Message from LOTW:
2022-05-25 07:54:55.8803 INFO: [LOTWManagement] : TQSL Version 2.6.2 [v2.6.2]
Signing using Callsign OO7F, DXCC Entity BELGIUM
Attempting to upload 25 QSOs
C:\Temp\LOTW_UPLOAD_20220525075453.adi: Log uploaded successfully with result:
File queued for processing
After reading this message, you may close this program.
Final Status: Success(0)
2022-05-25 07:54:55.8803 INFO: [LOTWManagement] : 0 success; log signed and uploaded and accepted without incident
2022-05-25 07:54:55.9272 INFO: [LOTWManagement] : [LOTW UPLOAD] INFO: LOG SAVED
2022-05-25 07:54:55.9272 INFO: [ClusterManagement] : Initiating cluster disconnection...
2022-05-25 07:54:55.9428 INFO: [ProgramScheduler] : Terminating program scheduler...
2022-05-25 07:54:55.9428 INFO: [#=zqW7jgklRVb68LkaY6fLvCZo=] : Closing remote control on port 2241
2022-05-25 07:54:55.9428 INFO: [SplashScreen] : Scheduler closed. Waiting 30 seconds for task ending
2022-05-25 07:54:55.9428 INFO: [#=zLliojSqfM_Fxpm99vQ0AykU=] : Closing UDP listener [disposed] on port 2237 for service WSJTX DIRECT/JT_MESSAGE
2022-05-25 07:54:55.9428 INFO: [SplashScreen] : Waiting pending asynchronous activities...
2022-05-25 07:54:55.9428 INFO: [SplashScreen] : Forced closure will take place within 60 seconds
2022-05-25 07:54:56.0992 INFO: [ClusterManagement] : Cluster(s) Disconnecting...
2022-05-25 07:54:57.1146 INFO: [TelnetConnection] : 44.144.11.254:8000 Disconnecting from 44.144.11.254:8000
2022-05-25 07:54:57.1146 INFO: [TelnetConnection] : 44.144.11.254:8000 Telnet connection closed
2022-05-25 07:54:57.1146 INFO: [ClusterManagement] : 44.144.11.254:8000 Disconnected
2022-05-25 07:54:57.1146 INFO: [TelnetConnection] : www.hb9on.org:8000 Disconnecting from www.hb9on.org:8000
2022-05-25 07:54:57.1146 INFO: [TelnetConnection] : www.hb9on.org:8000 Telnet connection closed
2022-05-25 07:54:57.1146 INFO: [ClusterManagement] : www.hb9on.org:8000 Disconnected
2022-05-25 07:54:59.0360 INFO: [SplashScreen] : Asynchronous activities completed
2022-05-25 07:54:59.0514 INFO: [SplashScreen] : Starting backup...
2022-05-25 07:54:59.0670 INFO: [BackupManagement] : Starting backup process
2022-05-25 07:55:00.7229 INFO: [BackupManagement] : Backup folder is set to C:\LOG4OM\Backup\
2022-05-25 07:55:00.7229 INFO: [BackupManagement] : Backup monthly folder is set to C:\LOG4OM\Backup\Historic\
2022-05-25 07:55:01.4102 INFO: [AdifManagement] : Begin export to ADIF file: C:\Users\OO7F\OneDrive\Kurt\Backup\LOG4OM\OO7F_20220525_075500_backup.adi
2022-05-25 07:55:02.9880 INFO: * [AdifManagement][1577 ms] : Export to ADIF file completed: 10493 QSO
2022-05-25 07:55:02.9880 INFO: [BackupManagement] : Backup created: C:\Users\OO7F\OneDrive\Kurt\Backup\LOG4OM\OO7F_20220525_075500_backup.adi with file size of 18292409 bytes
2022-05-25 07:55:03.3161 INFO: [BackupManagement] : Backup copied to : C:\LOG4OM\Backup\Historic\OO7F_May22_config.json with file size of 34310 bytes
2022-05-25 07:55:03.3161 INFO: [BackupManagement] : Backup copied to : C:\Users\OO7F\OneDrive\Kurt\Backup\LOG4OM\OO7F_20220525_075500_config.json with file size of 34310 bytes
2022-05-25 07:55:03.3161 INFO: * [BackupManagement][4249 ms] : Backup process terminated
2022-05-25 07:55:03.3161 INFO: [SplashScreen] : Backup completed
2022-05-25 07:55:03.3161 INFO: [SplashScreen] : Closing user profile...
2022-05-25 07:55:03.3161 INFO: [#=zoabdDRZX7ubG85x0bVBfNII=] : Closing running user profile
2022-05-25 07:55:03.3161 INFO: [SplashScreen] : User profile closed
2022-05-25 07:55:03.3317 INFO: [ProgramScheduler] : Saving system scheduler configuration in file C:\Users\OO7F\AppData\Roaming\Log4OM2\scheduler.xml
2022-05-25 07:55:03.3317 INFO: [ProgramScheduler] : Saving user scheduler configuration in file C:\Users\OO7F\AppData\Roaming\Log4OM2\user\scheduler_4ce05b4e8c9e41f989932a22c2240c2f_user.xml
2022-05-25 07:55:03.3317 INFO: [SplashScreen] : Scheduler saved
2022-05-25 07:55:03.3473 INFO: [SplashScreen] : Closing windows...
2022-05-25 07:55:03.3473 INFO: [#=zhWiMeYqWk0c4BIG1AfEKNooWFpEg] : Saving program configuration
2022-05-25 07:55:03.3473 INFO: [ConfigurationLogic] : Saving program configuration in: C:\Users\OO7F\AppData\Roaming\Log4OM2\user\config.json
2022-05-25 07:55:03.3785 INFO: [ConfigurationLogic] : Program configuration saved
2022-05-25 07:55:03.3942 INFO: [SplashScreen] : Program configuration saved
2022-05-25 07:55:03.3942 INFO: [SplashScreen] : Reporting usage data
2022-05-25 07:55:03.4723 INFO: [#=zJRT2wG9ZoLh2186ezQ==] : 73 see you soon...
Posted: 09 Jun 2022, 02:17
by k3uk
I had this working as a rookie in my my first week , a couple of weeks ago. However I had to move this to a new computer yesterday , so set up Log4OM again from scratch . It now hands when I close the program, just like the post earlier in this thread. I don't think I am trying to upload 10,000+ . I assumed it would just upload the few I worked today. My database is from a ADIF file I exported from Log4OM on my other computer.
Andy K3UK
