CAT stopped working after using N1MM
Posted: 30 May 2022, 10:04
by VK3IU
The CAT interface worked fine for several weeks no setting changed.
This weekend I used N1MM (stand alone) for the CQ WPX, when I started Log4OM, after N1MM closed, restarted pc, there is no more communications to the Radio, nothing. While N1MM when started up again has no communications issues.
HAMLIB FT-1000MP
COM port is a pci card with two COM ports
I upgraded Log4OM to V2.22.0.0
I am lost what else to do
Re: CAT stopped working after using N1MM
Posted: 30 May 2022, 11:13
Page 218 of the current user guide when setting up to use N1MM and the reverse CAT set up when reverting to just using Log4OM
Posted: 31 May 2022, 06:17
by VK3IU
thanks for the reply. I seems that I have a different manual (downloaded the latest) Page 218 "N1MM Contest Logger Integration" . I used N1MM in stand alone not interfaced with Log4OM.
But on a positive note, without really knowing what happened.
After I set the CAT Engine to "Nothing", saved the Configuration, started CAT interface, stopped it back to the CAT Configuration and set the CAT Engine to Hamlib, and suddenly Log4OM communicated again with my RIG.
73 de Klaus
VK3IU
