Full log deletion
Posted: 16 Jun 2022, 09:02
by iw7dmh
I am doing some tests on Log4OM v2 (portable version) with a MySQL database.
Everything works fine but I can't do a full log deletion using the QSO Manager.
I read about the Bulk Deletion on the manual, but, once I select all the qsos and hit the DEL button, the program stucks and after 10/15 mins I have to kill the Log4OM process.
In the database at the moment I have only 6500 qso but in the end, the number should reach about 150.000.
Thank you in advance for any help.
Best 73'
Enzo, iw7dmh
Re: Full log deletion
Posted: 16 Jun 2022, 09:17
Enzo,
Try deleting in the recent QSO window instead
Posted: 16 Jun 2022, 12:06
by iw7dmh
thank you very much for the answer.
I unlocked the QSO list, then selected all the QSO with the second bottom-left button the hit the DEL button.
Unfortunately the behaviour is the same: the main window is freezed, than I have to kill the process.
Maybe I am missing something
73' Enzo
Posted: 16 Jun 2022, 13:54
sounds like something associated with MYQSL operation because I tested with SQLite and this does not occur
I suggest that until we can check this our that you create a new database and use MySQL Manager to delete the existing database from MySQL
Posted: 16 Jun 2022, 16:58
by ei6kw
Enzo,
Did you try to tick "Drop Current database.... " option in import window?
Posted: 17 Jun 2022, 07:00
by iw7dmh
Ok, dropping the database worked fine.
Also doing a deletion using MySql Workbench worked (obviously) fine.
Anyway, I selected only ten (10) qso and tried again a bulk deletion. This could happen more frequently then a full deletion. The result was only one qso has been deleted.
So I extracted the debug log and, as you can see below, the [DeleteQso] function causes the systematic error [EXCEPTION] Parameter 'QsoId' has already been defined..
Maybe this can help Andrea in finding and fixing the error.
Note that all the qsos were imported from an ADIF downloaded with the Lotw Report function.
73' Enzo
iw7dmh
Code: Select all
2022-06-17 06:48:54.0745 DEBUG:     * [Countries][SearchCallsign][3976 ms] : Performing Search Callsign on call G8HXE on date 17/06/2022 06:48:54
2022-06-17 06:48:54.4824 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:54.4951 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:54.5078 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
                                      [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
   in MySql.Data.MySqlClient.MySqlParameterCollection.InternalAdd(MySqlParameter value, Nullable`1 index)
   in MySql.Data.MySqlClient.MySqlParameterCollection.AddWithValue(String parameterName, Object value)
   in L4ONG.DAL.MYSQL.DbMysql.DeleteQso(List`1 qsoIds)
2022-06-17 06:48:55.1699 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
   in L4ONG.Controls.QsoControl.UCQsoGrid.#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==.MoveNext()
2022-06-17 06:48:55.2824 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.2824 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.2824 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.2824 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.2938 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.3050 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.3050 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.3050 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.3160 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.3160 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.3160 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.3160 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.3388 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.3388 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.3388 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.3388 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.3512 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.3512 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.3608 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.3608 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.3728 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.3728 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.3728 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.3728 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.3947 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.3947 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.3947 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.3947 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.4055 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.4055 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.4055 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.4055 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:55.4280 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137606
2022-06-17 06:48:55.4280 INFO:        [DbMysql] : DELETE QSO WITH SQL PARAM QsoId 20220617063137610
2022-06-17 06:48:55.4280 ERROR:       [DbMysql][DeleteQso] : MYSQL DeleteQso exception while removing QSO (multiple)
2022-06-17 06:48:55.4280 ERROR:       [#=zjg9esO6JtquMjotlUn2mZ91_yIu8q7a8sg==][MoveNext] : [EXCEPTION] Parameter 'QsoId' has already been defined. MySql.Data.MySqlClient.MySqlException (0x80004005): Parameter 'QsoId' has already been defined.
2022-06-17 06:48:57.7486 DEBUG:       [Countries][SearchCallsign] : Performing Search Callsign on call DK6AH on date 17/06/2022 06:48:57
