Missing Awards
Moderator: OE6CLD
F4BPO
Missing Awards
Post by F4BPO »
My award folder is empty (only have sota, iota) nothing else.
Where can I find all the awards files ?
I am running last beta version (portable version)
73 de F4BPO Greg
Re: Missing Awards
You probably turned them off in the program config
F4BPO
Re: Missing Awards
Post by F4BPO »
They are all active unfortunately.
Actually when I go to utility and award manager if I double click for example on WAS and go to reference tab, the list is empty.
Is there a way to find all the json/xml files for all the awards somewhere ?
I thought updating awards would help but it did not change anything.
73 de F4BPO Greg
Re: Missing Awards
Try installing the latest beta 2.22.0.2
Have you tried.............
Settings/update resources/Log4OM awards
Settings/maintenance/Rescan QSO references
Settings/maintenance/Rebuild statistics
And your certain that you dont have any inactive awards in the config?
F4BPO
Re: Missing Awards
Post by F4BPO »
I have tried yes and also some previous versions.
I have updated resources Log4OM awards.
I have rescanned QSO ref as well as rebuild statistics.
I see this error in the log not sure this is relevant.
As you can see they all are active.
The problem is I see no reference, this is for example for WAS award
Thus in any QSO with USA when I am in award tab the dropdown list to chose the state is empty.
73 de F4BPO Greg
Re: Missing Awards
Try exporting your log to an ADIF then reimporting it to a NEW database, the message indicates a bad sector where the database is stored
F4BPO
Re: Missing Awards
Post by F4BPO »
Recreated new db on mysql and re-imported the ADIF but that does not change anything.
Also tried to create a new SQLite db and re-importing ADIF, even a new SQLite Db when I go to award manager anyway the refrences are empty for 99% of the awards.
Where are saved the xml files for awards ? Cause in the folder config/awards there is nothing except 3 .json which are not xml files.
73 de F4BPO Greg
F4BPO
Re: Missing Awards
Post by F4BPO »
Ok fresh install works so I will restart from scratch.
73 de F4BPO Greg
