Extra UDP port opened
w9mdb
Post by w9mdb »
It seems Log4OM 2.23.0.0 opens up the same port as JTAlert opens to WSJTX.
The 2236 is the connection for JTAlert.
2238 and 2343 are NOT set up as anything in Log4OM. 2238 is the port I have in JTDX for the multicast JTAlert Reporting setup. Seems Log4OM could only get the port# from JTAlert. I don't know where 2343 comes from at all.
2236 is form another WSJTX instance I run sometimes.
You can get this list using an admin cmd prompt and "netstat -q -b -n"
[L4ONG.exe]
UDP 0.0.0.0:2236 *:*
[L4ONG.exe]
UDP 0.0.0.0:2238 *:*
[L4ONG.exe]
UDP 0.0.0.0:2343 *:*
