OMNIRIG shutdown
Posted: 20 Aug 2022, 03:26
by K0HB
If using the program in standalone mode I set my CAT control to OMNIRIG.
On a contest weekend I use N1MM+ for CAT control, and feed my N1MM+ data to Log4OM via UDP. In this case I launch Log4OM first, and set CAT Engine to "Nothing". Log4OM then (as expected) shows frequency as "OFFLINE", but OMNIRIG actually continues to "lurk" in a running state, preventing N1MM+ from assuming control of the CAT.
To get rid of this OMNIRIG instance it is necessary to exit Log4OM completely, and then re-launch both Log4OM and N1MM+.
It would be nice if setting CAT Engine to "NOTHING" in Log4OM would effect a complete termination of OMNIRIG.
Re: OMNIRIG shutdown
Posted: 20 Aug 2022, 08:49
by PE5TT
I suggest using DXlog.net instead of N1MM , it supports Omnirig so Log4OM and DXlog.net can use the transceiver simultaneously
Posted: 20 Aug 2022, 14:42
by KI5IO
PE5TT wrote: 20 Aug 2022, 08:49
Marcel,
Looks like a good option. I'm downloading to look it over for the few times I use n1mm.
Tnx for suggestion.
Posted: 23 Aug 2022, 05:15
by K0HB
N1MM+ is ingrained into my contesting workflow, just as is Log4OM for my "main station log". At age 82, I need to stay with the programs which are part of my "muscle memory". I use Log4OM everyday, and N1MM+ at least once a week for some contest or another.
So I appreciate the suggestion, but respectfully repeat my original request.
Could Log4OM please release OmniRig without requiring an exit and relaunch.
Posted: 23 Aug 2022, 08:52
by KI5IO
K0HB wrote: 23 Aug 2022, 05:15
Hans,
I've added your request to the Mantis list for consideration.
