Start time
Posted: 23 Sep 2022, 07:44
by G4AON
I'm using version 2.23.0.0
In the past, I am fairly certain that when I clicked on a station on the DX Cluster it set the time when I moved the mouse and clicked on Operators name, Note area, etc.
Now I see the Start time is not fixed to the time of clicking elsewhere, it only seems to fix the time if I manually enter a call and press <TAB> to move to another field. It doesn't fix the time if I type a call and click the mouse elsewhere either.
I have tried ticking and un-ticking the "Set QSO Start time when leaving callsign field" but it doesn't resolve the issue.
Any ideas?
73 Dave
Re: Start time
Posted: 26 Sep 2022, 07:00
by G4AON
I have resolved the issue, version 2.22.0.0 doesn't suffer from the start time problem that has appeared in ver 2.23.0.0, so I have reverted back to the earlier version.
73 Dave
Re: Start time
Posted: 26 Sep 2022, 09:46
Re: Start time
Posted: 26 Sep 2022, 11:20
by G4AON
Terry, the check box in config could be updated to give the option that worked well in 2.22.00.
The problem occurs when clicking on a cluster spot with a mouse, you don’t naturally then reach for the keyboard <TAB> key, you are likely to click with your mouse… in 2.22 that froze the start time, but doesn’t in 2.23, hence my reason for querying the issue in the first place.
73 Dave
Re: Start time
Posted: 27 Sep 2022, 08:24
by N1FG
Hi Dave,
Don't know if this may help, but what I do is to use the mouse to click the lock icon on the start time when I start the QSO. You don't have to use the keyboard at all.
Larry N1FG
Re: Start time
Posted: 27 Sep 2022, 11:01
G4AON wrote: 26 Sep 2022, 11:20
73 Dave
Well my normal next action is to record the RST received from the other party which requires me to either tab to the RST field or mouse click in it, either of which moves the cursor and sets the start time
Re: Start time
Posted: 09 Oct 2022, 20:16
by SP5NZF
I use mouse not keyboard because I move to OP and comments (RST usually stays untouched).
IMHO p.35 of the manual i.e. (time is freezed when one leaves Callsign field ) dictates proper behavior.
I know it is not a critical bug but it IS very annoying and creating many errors in QSO start time (important for contests) and degrading user experience.
So prompt fix will be much appreciated.
Best regards and thanks again for great logbook!
