28.0 to 29.7 MHz Cluster Band Map view
Posted: 05 Oct 2022, 13:20
by ik5baf
Few days ago I installed Log4OM v.2.23.0.0 and after some general configurations, I have difficult to see the entire 10 meter Cluster Band Map view. I placed, also, an additional Cluster Band Map view outside the main Log4OM window, but the space for all 10 meter band (28.000 to 29.700 KHz) are not sufficient. The minimum zoom is Scale 1x, may be necessary a lower scale type Scale 0.5, 0.25 and so? On my PC, I am using 1920x1080 resolution and font size at minimum 100 percent on 24” screen. I try to attach a screen shot of my view.
Re: 28.0 to 29.7 MHz Cluster Band Map view
Posted: 05 Oct 2022, 14:49
So use two or more band maps, one for the top part and the other for the lower part of 10M - Its a huge band
Posted: 05 Oct 2022, 15:50
by ik5baf
Hi Terry. Thanks for your prompt reply. On the drop-down menu at top left if my choice is 10m, my maximum view is approximately from 28.400 to 29.300 KHz, for my opinion I need a zoom out lower than "Scale 1x", I am at minimum zoom out (Scale 1x) and if I scroll down with wheel mouse the band move to 6 meter. I tried to use more than one Cluster view but the result is the same.
73 de Marco, IK5BAF
Posted: 06 Oct 2022, 07:13
Works for me - Also using 1920 x 1080 display resolution
- Bandmaps new.png (121.67 KiB) Viewed 404 times
Posted: 06 Oct 2022, 08:45
by ik5baf
Terry
I will try in an other PC and I will see what happens.
73 de Marco, IK5BAF
