RTTY with FLDigi - Log4OM and FTdx101D
F6FLU
Post by F6FLU »
I need help
I have been trying for several days to make FLDigi and Log4OM work together with my Yaesu FTdx101D but without success
I)
1) following the description of the documentation (page 219 and following):
- If I use Hamlib as in the example, the CAT does not work, the frequency displayed in FLDigi remains fixed
- If I use RigCat then there the CAT works perfectly
II)
the problem is that I can't transmit on the FT101, I have of course tried several configurations but without success
3) If I use FLDigi standalone, it works perfectly, but as soon as I launch Log4OM I can no longer transmit from FLDigi
I think these are settings I can't make.
Does anyone use this same configuration ie : FLDigi - Log4OM but with a Yaesu FT101?
Thank you in advance if you want to try to help me
Dan - F6FLU
https://F6FLU.org
