Internal cluster server filtering
Is there any way to apply filters to the internal cluster server? I use WFView as my rig control for my ic7300. Wfview has built in spectrum and waterfall and now has cluster support. I did manage to get wfview and log4om connected via localhost:23 and it's working fine. I'm assuming the the log4om internal server gets it's feed from the server, or servers, I've setup in the cluster configuration. At least that appears to be the case, however while I can filter the built-in cluster to show bands and/or modes, the same filtering does not apply to the internal cluster server. So, is there any way to apply band/mode filters to the internal cluster server?
Re: Internal cluster server filtering
Why not just filter at the origin by sending filter commands to the DXSpider cluster or whichever one you use?
