Restoring from Backup
VE7ATJ
Post by VE7ATJ »
Again, another newbie question...
I'm wondering how to restore the program db from one of the 'backed up' versions? I have automatic backup set up for my PC, and the two files created in the folder are the .json for the config and the .sqllite for the db.
How do I tell the program to restore from one of the backup db files? Is there a way to do this?
The manual only talks about restoring from an .adif file.
Don VE7ATJ
Re: Restoring from Backup
If the backup files are .sqlite then just copy the backup file to wherever you want to run the logbook database from. You might want to change the name that's your choice
I will attend to the manual today
VE7ATJ
Post by VE7ATJ »
OK, that's great! Many thanks for the quick response.
Much appreciated.
What I'm trying to do is 'try some stuff' with ADIF import and wanted a way to 'go back to the start' if it failed.
Thanks again
Don VE7ATJ
VE7ATJ wrote: 17 Oct 2022, 15:54 OK, that's great! Many thanks for the quick response.
Much appreciated.
Thanks again
Don VE7ATJ
Make sure that your saving backups before experimenting
