QSL manager LoTW download changes SAT name
KB2YSI
Post by KB2YSI »
I have seen the QSL manager download change the SAT name for a contact that does not reflect the QSL'ed information from LoTW:
Log4OM_log_20221024014245-swapping-sat-names.txt
Code: Select all
Begin FULL ADIF generation request
Login kb2ysi
Begin ADIF download. May take some time...
RESPONSE file downloaded...
Parsing FULL ADIF file...
ADIF FULL document parsed: 682 qso found.
[14]N0GVK|10/11/2022 01:59:01 AM|2m|USB
     SATELLITE NAME updated from RS-44 to SO-50
[14]N0GVK|10/11/2022 02:23:12 AM|2m|USB
[28]KG0D|10/1/2022 04:00:38 PM|2m|FM
     SATELLITE NAME updated from AO-91 to RS-44
[28]KG0D|10/1/2022 04:16:44 PM|2m|USB
As you can see the 02:23:12 contact was SO-50:
However the 01:59:01 contact was on RS-44:
I re-ran the same download and it tries to flip them to RS-44, but in the saved log neither are RS-44:
Code: Select all
[5]N0GVK|10/11/2022 01:59:01 AM|2m|USB
     SATELLITE NAME updated from SO-50 to RS-44
[5]N0GVK|10/11/2022 02:23:12 AM|2m|USB
Re: QSL manager LoTW download changes SAT name
Log4OM is using the data downloaded from LOTW to update the database so if the downloaded data received from LOTW shows different to that recorded in your logbook it gets updated
Check the LOTW (Incoming) download file in Log4OM and check what LOTW sent you on the download
