SQLITE database
vk2vh
SQLITE database
Post by vk2vh »
Hi all,
How do I look at the logs in the database?
There are a number of SQLite files but I cannot seem to be able to open them to see the logs.
Or, are the logs viewed another way???
Regards
Rob
VK2VH
Re: SQLITE database
If you want to open an Sqlite database outside of Log4OM you will need to download an SQLite database management program.
However I warn you that you will probably screw up the data and make it unusable if you lack the knowledge!
Why and what 'Log' do you want to inspect???????????
vk2vh
Re: SQLITE database
Post by vk2vh »
Thanks for your reply.
I want to be able to view my logs of my contacts.
Regards
Rob
VK2VH
Re: SQLITE database
Just view them in the Log4OM recent QSO window (F7) or QSO manager!
Have you read the user guide?
Screenshot 2022-11-01 223927.png (66.72 KiB) Viewed 1506 times
vk2vh
Re: SQLITE database
Post by vk2vh »
Yes I have read the user guide.
I thought the logs were saved in a database as well.
What is the SQLite database used for?
Cheers
Rob
VK2VH
Re: SQLITE database
The sqlite database is where the log is stored
The recent QSO screen displays what is stored in the SQlite database
When you do a search using the filters Log4OM searches the SQLite database
What other reason do you have for wanting to open the Sqlite database?
Re: SQLITE database
If you REALLY must open the SQLite file then this will do it. https://sqlitestudio.pl/
Be aware that if you don't have knowledge of databases then you might do irreparable damage and we will not be able to help you resolve that
vk2vh
Re: SQLITE database
Post by vk2vh »
Thanks for your help.
My knowledge of computers is quite limited.
I just assumed that the logs would be stored as an "adif". I am unfamiliar with the SQLite database.
Cheers and thanks again...
Rob
VK2VH
