avvio rcerca nominativo
Posted: 01 Nov 2022, 15:48
by ik6hsm
un saluto
ultimamente inserendo manualmente un nominativo nel campo call non si avvia la ricerca automatica
sui server (qrz o qth,ect,,) cosa che avviene selezionando un nominativo dalla lista cluster :qualcuno può aiutarmi ?
grazie
carlo
Re: avvio rcerca nominativo
Posted: 09 Nov 2022, 11:21
by ik6hsm
salve
quando scrivo un nominativo in campo call non si avvia data lookup : perchè?
grazie
cc
Posted: 09 Nov 2022, 13:26
by KI5IO
What do you have set up for Info Providers?
Posted: 09 Nov 2022, 18:06
by ik6hsm
uguale , ma non si avvia la ricerca
Posted: 09 Nov 2022, 18:25
by KI5IO
Carlo,
Enable the 'Trace' log level at: Help / Log Level then select 'Trace'
Then manually key in a callsign or two or three. Can also tab out of the callsign field once you enter the callsign.
Then open the log that has been generated at: Help / Open Log File .... take a look toward the bottom of that log and see if anything might give you a clue as to the lookup not starting.
BTW - do you have an active internet connection when doing this lookup?
Posted: 09 Nov 2022, 23:01
Load 2.24.0.0 and there are changes to the 'Look up call when leaving call sign field' operation which are identified in the latest user manual
Choice of performing lookup when using the 'Tab' button to leave the field or when placing the cursor in another field
Posted: 10 Nov 2022, 05:26
by ik6hsm
Using the TAB key the search starts (it seems to me in the past it started without TAB)
I install 2.24 (I didn't notice the update)
the log is very interesting.
thank you so much
Charles
