LoTW upload not working
Re: LoTW upload not working
Set trace mode in help menu, attempt an upload then send either Lele or me a support request from the help menu please
Where do I send the zip file to please Terry, I can not see any details on the support request section
Either Lele IW3HMH or Me G4POP, both email addresses on QRZ - Lele is best choice
Ok thanks, should have guessed that,
Trevor
EI2GLB
Trevor
EI2GLB
I also have had this issue pop up in the past and TQSL needed an update or Cert, seemed to resolve the issue. Now the freezing on exit and worse, freezing of Log4Om totally if I leave the program running in the background with no use sometimes requires a total reboot to remedy. I have used Log4Om for 2 years no long term issues until version 2.23.0.0 this issue is almost a show stopper, unreliable logging is a real problem.
Today I Updated from 2.23.0.0 to 2.24.0.0 the freeze on exit when LOTW needs uploaded did not resolve the issue. I then changed the option in Log4Om to TQSL Interactive mode = Checked and the upload no longer hangs.
Version 2.5.0.0 seems to have cleared all issues that I had.
I had this issue.
Would get stuck in the process. When I switched to "TQSL interactive mode" it turned out TQSL was waiting for me to press the "update configuration" thing. Which it misteriously did not when I opened the TQSL program by itself...
Who knows....
Anyway, write this hete in case anybody else has some strange LoTW hanging issues....
73!
Who knows....
73!
