Hamlib issue in v 2.25.0.0
WR0H
Post by WR0H »
I am using a Flex 6600 with SliceMaster and connecting via Hamlib was working flawlessly through version 2.24.
I just upgraded to version 2.25 and now have a connection issue that rebooting/restarting the programs doesn't solve. The CAT/Hamlib settings were carried over from 2.24 as expected and the connection icons all are green, but in reality the radio is not communicating with Log4OM and the freqency display shows "OFFLINE". None of the settings changed during the upgrade, and when I downgraded back to 2.24 it connects immediately.
Here are my settings that are working with version 2.24 but not 2.25.
Re: Hamlib issue in v 2.25.0.0
Bill,
I had received an e-mail from Mike - w9mdb (Hamlib) and he advised of an issue with a version of Hamlib affecting Flex rigs.
They are working on an updated release that will likely be released soon.
Once done Lele will have to add into Log4OM.
WR0H
Post by WR0H »
Thanks--2.24 works fine so I'll stay with that until it gets lined out.
w9mdb
Post by w9mdb »
You can replace the hamlib in Log4OM in \Users\[username]\AppData\Roaming\LOG4OM2\Hamlib
From here -- unzip and copy the bin directory into there.
https://n0nb.users.sourceforge.net/
w9mdb wrote: 05 Dec 2022, 21:58 You can replace the hamlib in Log4OM in \Users\[username]\AppData\Roaming\LOG4OM2\Hamlib
Mike,
Tnx for the direction & update.
w9mdb
Post by w9mdb »
Flex problem has been fixed....
Download the zip file -- extract -- and copy all in the bin directory to C:\Users\[username]\AppData\Local\Log4OM2\hamlib
Mike W9MDB
