Weather option
Posted: 06 Dec 2022, 03:33
by kp4hf
Any way to disable the weather option? I don't use it.
Thanks.
Re: Weather option
Posted: 06 Dec 2022, 05:46
by DF5WW
Did you mean the Space Weather with A, K and the sunspots ? If yes there is no option to switch off. It´s hard coded in the main UI.
It´s an oversight for interested Hams and most of us find it useful.
Re: Weather option
Posted: 06 Dec 2022, 07:38
kp4hf wrote: 06 Dec 2022, 03:33
Thanks.
Did you try checking the user guide? ------ Page 185
Uncheck box at top labelled ''Enable weather engine'
- Untitled.jpg (76.43 KiB) Viewed 1509 times
Re: Weather option
Posted: 07 Dec 2022, 00:31
by ve3wej
unchecking the box does not stop the f11 weather tab from displaying here. I suggest may , since it is for cw, that it be moved to the cw window,
I wont ever use it here
Re: Weather option
Posted: 07 Dec 2022, 00:43
by KI5IO
ve3wej wrote: 07 Dec 2022, 00:31
Dave,
The F11 WX tab will remain on the Main UI, but it will not be refreshed with data when you un-tic the box.
If you prefer that the entire F11 tab be elsewhere put together a proposal and post in the Feature Suggestions portion of the Forum. With a good pitch, Lele might give that a consideration.
Re: Weather option
Posted: 07 Dec 2022, 00:44
by kp4hf
See attached picture for the option/tab. And yes disabling does not remove it.
Thanks.
Re: Weather option
Posted: 07 Dec 2022, 07:46
It is not primarily for CW its for reference during any mode and many of us will use it when having a phone QSO, it will remain unless there are a large number of users objecting to its presence.
