Page 1 of 2
Old version to use?
Posted: 09 Dec 2022, 09:35
by Pa0ply
I was used to have a log4om version in which it loaded the log from wsjt when you start log4om.
There was no need to run log4om at the same time you run wsjt while operating.
Can you advice which, older, version I should download?
Thanks in advance,
Jan, PAoPLY
Re: Old version to use?
Posted: 09 Dec 2022, 10:54
Nothing has changed you must have been using our ADIF monitor to read the WSJT ADIF file instead of the recommended integration method.
So no nothing changed just use the latest version 2.25.0.0
Posted: 09 Dec 2022, 11:02
by Pa0ply
I used the recommended link setup: upd inbound…. Wsjt_direct port 2237
This was also set in the wsjt-x settings
But when I start log4om, it doesnot read the log from wsjt-x.
Should I setup differently to automatically import QSO’s from WSJT when I start Log4OM?
Br. Jan
Posted: 09 Dec 2022, 11:05
The ONLY way log4om will import historic qso's from wsjt is by using ADIF monitor, NOT UDP
Posted: 09 Dec 2022, 11:16
by Pa0ply
Can you give me instructions how to setup for this using wsjt-x, please.
Thanks in advance,
Jan
Posted: 09 Dec 2022, 14:07
See our user guide re ADIF monitor
Posted: 09 Dec 2022, 14:10
by Pa0ply
I looked in there, of course, but where to find the adif file in wsjt-x.
Using search it did not find those files in the wsjt directory.
Br. Jan
Posted: 09 Dec 2022, 15:03
Should be shown in wsjt preferences I expect but I don't use wsjt only had it installed long enough to write our user guide and then removed it
Posted: 10 Dec 2022, 06:39
by DF5WW
C://user/username/appdata/local/wsjt-x
the file is called wsjtx_log
Posted: 10 Dec 2022, 08:09
DF5WW wrote: 10 Dec 2022, 06:39 C://user/username/appdata/local/wsjt-x
It will be something like WSJT_log.adi not the .log or .ini files
