I am attempting to integrate LOG40M with Win4Icom Suite and IC-7100.
I reviewed the Manual pp 225-227.
I created com0com virtual ports, which work well in Win4Icom for several other apps.
My problem: When I open in proper sequence, LOG40M does not sync with my IC-7100 or Win4Icom.
However, once I log out of Win4Icom, LOG40M does sync with the radio.
The proper setting in OmniRig is unclear in the instructions to me.
I don’t have the 5 tab Omni-Rig window as shown in the instructions. Only the 2 column, Rig 1 and Rig 2 version.
I have Rig 1 set for my 7100 as IC7100e4DATA on COM 3 for my radio. This works for all other apps linked to Win4Icom.
I am uncertain how to set Rig 2. I have the virtual Port pair set correctly. Your Example shows Elecraft KX3 as the Rig type. Neither that Rig Type nor setting Rig Type as an IC-7100xxx rig works. I have the Baud Rate matching @ 38400.
Is integration of Win4Icom with LOG4OM different than the setup for WSJT-X, DXLab, and Fdligi, which all implemented fine?
What can you recommend to me?
Synching with Win4Icom/IC-7100
Jump to
- News
- ↳ Country & Special Callsign file updates
- Log4OM v2
- ↳ FAQ
- ↳ General discussions
- ↳ User support
- ↳ Error reports
- ↳ Feature suggestions
- ↳ Country (LANGUAGE) Forum
- ↳ German language forum
- ↳ Spanish language forum
- ↳ Portuguese language forum
- ↳ French language forum
- ↳ Italian language forum
- ↳ Award Support
- Log4OM v1
- ↳ User Support
- ↳ Software Integration
- ↳ SDR & VSP
- ↳ Award support
- ↳ FAQ
- ↳ Error Reports
- ↳ Technical Information
- ↳ Send data to Log4OM
- ↳ Receive data from Log4OM
- ↳ Databases Etc.
