Download From eQSL
Posted: 17 Jan 2023, 07:50
by G8LIY
Hi
Trying to pick up where I left off some time ago (serious health issues)
www
I tried to start updating my Log...
I go to QSL Manager, Select eQSL and Search.
I select all the QSO's with "NO" for received, 796 shown from 806, and then Click on Download...
I get the Following output: (( note I have just put XXXX's to hide my Password and added some spaces in url for it to show ))
Request link: https: // www.eqsl.cc /qslcard/DownloadInBox.cfm?UserName=G8LIY&Password=XXXXXXXXXXXXXX&QTHNickname=RodeHeath&LimitDateLo=01%2f01%2f1900&LimitDateHi=01%2f17%2f2023
Sending ADIF generation request...
NO QSO FOUND searching for ADIF file
More info: https: // www.eqsl.cc /qslcard/DownloadInBox.cfm?UserName=G8LIY&Password=XXXXXXXXXXXXXX&QTHNickname=RodeHeath&LimitDateLo=01%2f01%2f1900&LimitDateHi=01%2f17G8LIY&Password=XXXXXXXXXXXXXX&QTHNickname=RodeHeath&LimitDateLo=01%2f01%2f1900&LimitDateHi=01%2f17%2f2023%2f2023
EQSL UPDATING STATISTICS...
EQSL END
If I login into eQSL I can see various counts in the Archive 241, Inbox 241 and Outbox 652,
There are options to download those as .adi files but not sure if this is the way to go..??
Any guidance welcome, Running v2.25.0
Many Thanks...
Re: Download From eQSL
Posted: 17 Jan 2023, 09:11
You refer to download but describe upload?
For download you don't need to search and select in Log4om just click download button set from date and download
I have just tested and the eQSL download works fine so I must assume that either your using the wrong user name or password or the wrong case - see my result below
Request link: https://www.eqsl.cc/qslcard/DownloadInB ... 2210010000
Downloading ADIF document from https://www.eqsl.cc/downloadedfiles/GK4L4298.adi ...
Parsing ADIF file...
ADIF document parsed: 20 qso found.
Updating DL4MAU|17/07/2017 05:32:00|60m|JT65...
Saved QSO locator (JN58vj) appears valid (not country default JO40vs) but different from EQSL reported (JN58uh). Keeping saved
QSO updated
QSO NOT FOUND: EA5HM|28/01/2020 11:16:00|20m|FT8
Updating OM7DX|05/02/2020 15:48:00|40m|FT8...
Saved QSO locator empty/default/shorter. Updating to JN98dr
QSO updated
QSO NOT FOUND: G1VWC|25/09/2021 07:12:00|80m|LSB
QSO NOT FOUND: ZL2AWW|15/11/2022 06:53:00|20m|FT8
QSO NOT FOUND: PP5XA|29/11/2022 15:45:00|15m|FT8
QSO NOT FOUND: 4L1004SWL|27/12/2022 17:11:00|40m|FT8
QSO NOT FOUND: CT2089SWL|27/12/2022 19:42:00|20m|FT8
SAVING QSO's...
SAVE COMPLETE
EQSL END
Or are you expecting to download complete QSO's that are not in your log? because that is not what the function does it just checks for confirmations and updates existing QSO's
Posted: 17 Jan 2023, 19:28
by G8LIY
To clarify.. I'm just trying to "Download" any "Confirmations"
I have confirmed my User Name / Password / Nickname is correct by logging directly back in to eQSL.
I use the same details in External Services in the Configuration in LOG4OM, My Password is plain Alpha/Numeric 14 Chrs
Just tried again, same result.?
Posted: 17 Jan 2023, 20:52
OK
Before proceeding please install 2.25.0.11 beta
Now
First put log4om into trace mode in the help menu
The attempt another download from eqsl
Finally send me the support request from help menu - please tick the include ADIF box
Email me the zip file to my address on QRZ
Posted: 18 Jan 2023, 18:50
by G8LIY
Sorry for delay... emails to be sent shortly.
Suffering from Fatigue after Chemo.
Regards
