Is it possible to have Log4OM counting the initials per band?
Br. Jan, PAoPLY
Counting initials per band?
Re: Counting initials per band?
Worked station, never worked before
Jan,
Have you looked in the User Guide and also about the information provided on the Cluster? Check out Cluster Highlight Colors on the screen clip below.
You access this at: Settings / Configuration / Cluster
- Config-Cluster.JPG (127.64 KiB) Viewed 1056 times
Try Statistics and award status displays from the view menu
Thanks for the suggestions.
Will try to get it solved.
Br. Jan, PAoPLY
Br. Jan, PAoPLY
