First The program 'lost' config.json and welcomed me as a new user.
I found a backup and fixed it. WHEW!!
Next CAT with omnirig or hamlib does not connect. I tried both.
omnirig is working fine with WSJTX.
I re-installed the program. No change.
Then I installed the new beta. No luck
There is a debug mode for omnirig, but I doubt it will show
Windows 10, IC-7610, Win4Icom
Help please
73, Bo W4GHV since '54
config.json gone, & CAT gone
https://www.qrz.com/db/W4GHV
Re: config.json gone, & CAT gone
Progress.
Eliminating Win4Icom, running only omnirig and Log4OM works.
So its not a Log4OM problem!
Omnirig cannot multithread unless it and the other programs are run as an administrator - All in our user guide
Yep. That's what I had wrong. Don't know how it got changed or the config.json getting clobbered.
All is well now!
Wondering if there is a way to bypass the 'ok' needed to start the admin required flags.
I found CWget needs to be run in admin mode too.
Thanks reply!
All is well now!
Thanks reply!
