Cluster Band Filters
w6my
Post by w6my »
No 15 meter band selection under cluster filters.
Version 2.26.0.0
Missing 15M Band.rtf
(179.66 KiB) Downloaded 65 times
Chip - W6MY
Re: Cluster Band Filters
Chip,
What have you selected at: Settings / Configuration / User Preferences ??
Look at the Preferred Bands column. Likely you have missed ticing 15m as one of your choices there.
Maybe go through the band selection process again and be sure to Save and Apply and then also restart Log4OM ... then look at your available band choices in the Cluster Filter section.
w6my
Post by w6my »
Thanks Nolan, you were spot on. A check under preferences, and all is good.
Thanks again,
Chip - W6MY
