I'm sure I'm just missing something small, but QSOs from WSJT-X are showing up in my Log4OM log but not being uploaded to any of the logbooks, even if I attempt to manually upload them. I discovered that QSOs entered manually are being uploaded. I discovered that on accident because I typed a callsign in just to do a lookup and I must have pressed <ENTER> because Log4OM uploaded that to all the logbooks.
Thank you,
Chris, N9XCR
QSOs from WSJT-X Not Uploading
Re: QSOs from WSJT-X Not Uploading
Did you use WSJT-X only or also JTalert ? If so you have to check in HTalert that it sends the QSO´s with QSL sent status "No" to Log4OM.
Mostly this is the Log4OM setting that it uploads onls "No" to other services. If JTalert ist set to "Requested" you have to change to "No"
in JTalert or to "Requested" in Log4OM.
