LOG4OM does not correctly understand the QRG
Posted: 24 Mar 2023, 16:03
Greetings! Thanks for the excellent software!
When I forward a QSO generated by Ham Radio Deluxe's logbook (I need it because of RTTY) over UDP connection, LOG4OM does not correctly understand the stream of numbers sent by Ham Radio Deluxe to designate the QRG. For example, when logging a qso in the HDR in the QRG of 700099 (40m band) Log4OM understands it as 70009,9 (And he put 4m band in log) when receives de UDP. I did everything I could, but I couldn't solve the problem. What should I do?
Thank you very much!
73!
73!
