Bearings
Posted: 22 May 2014, 14:51
by W3LI
Under F9 all bearings are 270/90 for state side stations?
Under Info F7 the map shows the correct location of the stations.
I am using Ham QTH. Why is this????
Andy, W3LI
Re: Bearings
Posted: 22 May 2014, 17:41
what callsign are you checking?
Re: Bearings
Posted: 22 May 2014, 21:57
by K7PT
Check each of those stations and see if they have a grid square or lat/long. If they don't the beam heading is to the geographical center of the U.S as a default.
Quite often this is the case with QRZ.
Chuck-K7PT
Re: Bearings
Posted: 22 May 2014, 22:30
by W3LI
Hi Guys, Tnx for the reply. The stations are as follows: wz8bd/8, wi9i, w4cbx, k8io, kg8co. I just realized that these are all 6m stations. The thing that is confusing is that the map F7 is correct. Chuck I am using HamQTH at ur suggestion some time ago.
Thank you Daniele and Chuck
Andy
Re: Bearings
Posted: 23 May 2014, 07:59
I tried setting your locator in my Log4OM and all the calls you reported.
I saw no errors, all bearings was correctly shown in map and degrees seems to be correct.
Setting a callsign will fill the right side fields in green color? (that means the data are collected from external sources)?
Re: Bearings
Posted: 23 May 2014, 20:59
by W3LI
OK Daniele Tnx. I never think to look on the right side.
