worked before tab entries
Posted: 28 Apr 2023, 22:31
by ve3wej
When I am trying to work w1aw/1, I expect only the previous /1 stations to show in the before (f10) tab. but all w1aw is showing
do I have a setting wrong, or is this incorrect results, and need fixing
Re: worked before tab entries
Posted: 30 Apr 2023, 15:51
by ve3wej
adding snip to show what I mean
Posted: 30 Apr 2023, 16:31
by KI5IO
Dave,
The lookup routine that Lele has in place has always (as best I'm aware) provided such results.
Mine does (and has always) provided the same results.
Terry and/or Lele may also add some additional input to your comment, but it is working as intended.
You might could post a request for lookup change parameters in the Feature portion of the Forum.
