Omnirig and Log4om
Posted: 30 Apr 2023, 18:28
I have a new to me Kenwood TS-590S that I am trying to establish CAT control with so it will communicate with Log4om. My question is regarding Omnirig settings. I have a Kenwood TS-480SAT that works perfectly set up on Rig 1 in Omnirig, and I have attempted to set Rig 2 as the TS-590S, with no joy. I am using the USB connection to the TS-590S, and it works perfectly with the Kenwood ARCP-590 rig control software, so I know the connection there is good.
Here are the particulars
Log4om 2 version - 2.27.1.0
Omnirig version 1.2
Both of these are run as administrator
Virtual COM port drive from Kenwood has been installed and is working (hence the connection with the ARCP software
Current Omnirig setup is as follows-
Rig type - TS-590
Port - COM7 (from Device Manager)
Baud rate - 115200
Data bits - 8
Parity - None
Stop bits - 1
RTS - High (had this originally set at Low and it didn't work)
DTR - High (had this originally set at Low and it didn't work)
Poll int.,ms - 1000
Timeout, ms - 2000
Would someone be so kind as to show their Omnirig settings? Any help would be greatly appreciated.
de W4CLW Charles Woodall
Omnirig version 1.2
Rig type - TS-590
Baud rate - 115200
Data bits - 8
Parity - None
Stop bits - 1
Poll int.,ms - 1000
Timeout, ms - 2000
