troubles to see cw callsign in the work band window.
hb9gur
Post by hb9gur »
I'm new on this forum, but I'm using log4om for a long time now.
I need help! I would like to know why when I click on a ssb call I can see it in the window on the right, When I'm in cw I cannot see any call sign on this same window... Can you help me to make cw available in the band's window. Thanks a lot read you soon 73 qro HB9GUR
Re: troubles to see cw callsign in the work band window.
hb9gur wrote: 25 May 2023, 13:28 Hello,
Philippe,
Couple questions:
What version of Log4OM are you using? Lele has just released V 2.27.1.10 https://www.log4om.com/download/ That we have been testing for some time now.
Check any filters that you may have selected on the Cluster (F8) tab.
I'm assuming that you are using QRZ.com as your primary Info Provider for the callsign lookups? In some cases not all OMs provide a 'profile image', but that is not limited to either CW or SSB so is not an issue in this case.
hb9gur
Post by hb9gur »
I'm using 2.27.1.0
Maybe I was not clear enough, Have a look at the 2 jpg. For the ssb we can see stations in the right window. But for cw not any station is visible in the same window! Why?????
Thanks for your help
73 qro HB9GUR
Philippe,
It is about the filters chosen. Each bandmap has its own set of filters to choose from.
See images below.
hb9gur
Post by hb9gur »
YES YES great... it works tnx a lot for your help 73 qro from Switzerland. HB9GUR
