QSO Upload to QRZ.COM and Clublog doesn`t work after update
Posted: 17 Jul 2023, 20:09
by dg3iam
Hello everyone,
after the last update to version 2.28.0.0
the automatic upload to Clublog, QRZ.COM etc. no longer works. Does somebody has any idea.
Also, the active call in WSJTX is no longer displayed in LOG4OM, but after the QSO it is included in the log .
73 de Ralf DG3IAM
Re: QSO Upload to QRZ.COM and Clublog doesn`t work after update
Posted: 17 Jul 2023, 21:11
by KI5IO
dg3iam wrote: 17 Jul 2023, 20:09
Hello everyone,
73 de Ralf DG3IAM
Ralf,
I'm going to assume that such affects your 'digital' (IE: FTxx) QSOs? You were not clear on that in your post.
Regardless ... Lele made substantial changes with the release of V 2.27.0.0 and how the UDP Inbound Connections are handled.
All the information is noted in the Release Notes and the "current" User Guide.
You need to DELETE your current/old UDP Inbound Connections and REBUILD NEW UDP Inbound connections and you will be good to go from there.
There are posts all over the Forum about the change and all that has been shared with OMs about this.
Review the Release Notes and the "current" User Guide. Delete and rebuild your UDP Inbound connections and you will then be OK.
Posted: 17 Jul 2023, 21:34
by dg3iam
OK thanks for Help, now it works...
i am seraching for this , but not deep enough .
73 de DG3IAM
