First of all, I want to congratulate you for the work you are doing.
I am a relatively new user of the log and I would have some suggestions if they can be applied...
I use log4om more offline. I still don't have a PC/laptop near the station.
Regarding the qso input window:
- Being an offline user (if I may say so), I would like there to be a button / switch / checkbox to switch the program to "offline" mode - that is, without connection to the station.
- For the date, I would be nice to be only one field (start or end)
- I don't use the 'RXfreq' and 'RXband' fields either.
At the moment I do not use the automatic upload of qso's. I would be nice to have some 'checkboxes' with the order in which the upload should be done (1,2,3...). I upload to many qso managers in the following order: EQSL, HAMQTH, HRDLOG, CLUBLOG, LOTW, QRZCOM. This is so that the referrals to the other qso manager sites are also registered on the QRZ.
Recently, in the QSO Manager window at QRZ, under Download confirmations, qsos that are being downloaded appear in the list every time... Should I ask the people at QRZ about this?
Thank you, Bogdan
I am attaching a part from the log of 'Download confirmations'
Code: Select all
Beginning download from https://logbook.qrz.com/api?key=4412-F031-5995-24D8;ACTION=FETCH;OPTION=STATUS:CONFIRMED;BETWEEN:2023-08-06+2023-08-09
Download completed.
Declared data: COUNT=287 records
Parsing log...
Log contains: 287 records
Callsign: HB9TWG Date: 02.06.2012 12:52:23 Band: 20m Mode: SSB ### ALREADY CONFIRMED ###
Callsign: DL3LE Date: 04.06.2012 18:23:00 Band: 6m Mode: SSB ### ALREADY CONFIRMED ###
Callsign: DL3WA Date: 10.06.2012 08:32:00 Band: 6m Mode: SSB ### ALREADY CONFIRMED ###
Callsign: YO9AKM Date: 03.07.2023 17:40:07 Band: 20m Mode: USB ### UPDATED ###
Callsign: HZ1TT Date: 04.07.2023 15:47:07 Band: 20m Mode: USB ### ALREADY CONFIRMED ###
Callsign: 4U1A Date: 22.07.2023 09:17:29 Band: 20m Mode: USB ### ALREADY CONFIRMED ###
Callsign: YB0AR Date: 26.07.2023 17:24:51 Band: 20m Mode: USB ### ALREADY CONFIRMED ###
QRZCOM UPDATING STATISTICS...
QRZCOM END
