Hamlib CAT interface - Generated parameter String ERROR
iz5fsa
Post by iz5fsa »
Hi OMs.
During holydays I've spent my time to reach a goal: setup hamlib CAT interface on LOG4OM + FLRIG + WSJT/JTDX. I've spent time handling Configuration / CAT Management / Hamlib / "generated parameter string" by hand with rigctl and rigctld in verbose mode.
Errors found in rigctl/rigctld params:
  • "--port=4532" that is not recognized and must be changed with "-t 4532";
  • "--rig-file=COMx" must be changed in "-r COMx".
Another error occurs, but it depend on my personal config for the YAESU FTDX101D/FY991A: the "--set-conf=stop_bits=2" is not recognized but can be omitted with no impact on radio use.
Setting up LOG4OM CAT interface with hamlib with right params...
Screenshot 2023-08-21 214318.png (77.15 KiB) Viewed 4342 times
You can set up FLDIGI CAT interface using "Hamlib NET rigctl (Stable)" in Rig definition, with "localhost:4532" string in Device field cleaning Advanced configuration field...
Screenshot 2023-08-22 204407.png (34.47 KiB) Viewed 4324 times
and with other Log4OM/Fldigi setup all woks fine (double click on Log4OM spot set up frequency/mode on radio and also on FLDIGI plus callsign in the spot!
For WSJT/JTDX the "Hamlib NET rigctl" can be used in the rig selection.
Screenshot 2023-08-21 214928.png (34.48 KiB) Viewed 4342 times
Using this setup don't need any serial port splitter added.
I hope this can help users and software / documentation maintainers!
73 de Leo IZ5FSA
73 de Leo IZ5FSA
w9mdb
Re: Hamlib CAT interface - Generated parameter String ERROR
Post by w9mdb »
You've done it the hard way
Set up FLDigi to use FLRig
Set up WSJTX to use FLRig
Set up Log4OM to use FLRig
Screenshot 2023-08-27 160040.png (50.7 KiB) Viewed 4293 times
iz5fsa
Post by iz5fsa »
Yes, it works fine also.
thanks
73 de Leo IZ5FSA
iz8ewd
Post by iz8ewd »
Problem solved now.
https://github.com/Hamlib/Hamlib/commit ... 1c6d40dfa6
Update to the last Hamlib 4.6 beta snapshot.
