TCIP CAT Control for K4
Posted: 06 Sep 2023, 11:24
by af1e
It would be great to be able to use TCIP CAT control for the Elecraft K4. See picture on how I connect WSJTX to my K4D. Works great and eliminates a comm port. Current TCIP CAT in Log4OM does not work even if I specify my K4's IP instead of its network name.
Thanks.
Joe AF1E
Re: TCIP CAT Control for K4
Posted: 06 Sep 2023, 12:10
Doesnt Hamlib ir Omnirig have a rig ini for the K4?
Posted: 06 Sep 2023, 12:54
by af1e
Both Hamlib and Omnirig support the K4 fine and I have used that, but using the Ethernet port instead of the serial connections would allow operation from a computer that is not hooked to the radio. I can accomplish this using Win4K4Suite but that adds a level of complexity.
Joe AF1E
Posted: 21 Nov 2023, 20:20
by k4em
Too bad the K4 doesn't have TCI capability, that works great here. I have Log4OM, JTDX, my rig Anan 7k DLE MKII and amp RF-kit; controlled via TCI.
Only issue is the Anan software does not implement the TCI audio protocols, that's used for digital modes. I still have to use VAC for audio control.
Dave
k4em
