Hi guys,
I don´t know if someone can help me on this matter. Recently i installed the Log4om and i worked a lot of time with JTDX before. After installed the log4om and setup the omnirig for my radio Icom -7300 i noticed every time i use the jtdx it changes the filter on my radio. Normally i use the FIL1 (Filter1) with a bigger bandwith than the others, but jtdx still change the filter for FIL2 witch has a shorter bandwith for FT8. If i use only JTDX with the omirig it changes the filter, but if i used the hamlib instead it works fine. But on this mode i can´t work with log4om because they use the same port. I already tried vspe but the problem still there. If you can advise on this matter please let me know.
Best regards
José CT1EDG
Wrong filter selection on Icom 7300
Return to “General discussions”
Jump to
- News
- ↳ Country & Special Callsign file updates
- Log4OM v2
- ↳ FAQ
- ↳ General discussions
- ↳ User support
- ↳ Error reports
- ↳ Feature suggestions
- ↳ Country (LANGUAGE) Forum
- ↳ German language forum
- ↳ Spanish language forum
- ↳ Portuguese language forum
- ↳ French language forum
- ↳ Italian language forum
- ↳ Award Support
- Log4OM v1
- ↳ User Support
- ↳ Software Integration
- ↳ SDR & VSP
- ↳ Award support
- ↳ FAQ
- ↳ Error Reports
- ↳ Technical Information
- ↳ Send data to Log4OM
- ↳ Receive data from Log4OM
- ↳ Databases Etc.
