Using Log4OM2 v2.28.0.0 and User Manual 07/09/2023
Net Control p44
The manual suggests that double-clicking a callsign in the On Air table should bring up a QSO edit screen. In my version a double-click saves the QSO and moves the callsign back to the Net User table on the right-hand side of the window. Editing Net Users via the pen icon before they join the net works fine and as described in the manual.
You are also able to select several Net Users in one go and drag the group across to the On Air table (useful feature not mentioned in the manual). However, the reverse can't be done en masse to close several QSOs in one go.
Note "is" typo in Closing a net para.
Hope this helps.
Thanks.
Ian.
User Manual Error
Re: User Manual Error
Thank you for the heads up, edited and currently uploading revission
