UDP Ports?
vk4sx
UDP Ports?
Post by vk4sx »
Dennis vk4sx, I have an issue, LOG4OM2 stopped AUTOMATIC UPLOADS to LOTW, No warning it wasn't uploading, just was going thru the motions but no auto upload,
I was informed by more capable Log users then myself that LOTW stopped uploading on 6th NOV 2021, (V 2.18.0)
LOG4OM2 displayed correct shut down procedure of upload,
no warning no nothing,
I had two experienced users port to my system and both found everything to be 100% ok
Matt processed a Manual upload with no issues,
of course all this is after 2-3 weeks or starting a fresh on a NEW OS WIN 11 install using V2.29
version that was being used when LOTW uploads stopped , was v2.18.0, LOTW Auto uploads stopped on that version,
Auto LOTW uploads STILL DO NOT work on V 2.29
I was informed it was a UDP Port Issue?/
manual upload using QSL Manager works 100%
has anyone any ideas how to get AUTO LOTW uploads functioning
NO evidence of an issue is shown on the LOG4OM2 shutdown procedure page, it displays all procedures as working
but it isn't
Kind Regards
Dennis vk4sx
ve3wej
Re: UDP Ports?
Post by ve3wej »
I usually do a manual upload when I am done for the day, so I have turned on automatic, and will see if 2.30.1.0 works.
not really sure this is a udp issue, though. it would be a tqsl issue, if your certificate has expired maybe
Dave ve3wej / ve3ie
