Double clicking on cluster spot puts IC7300 in CW-R mode
ve3nr
Post by ve3nr »
When double clicking on a cluster spot, spotted stn working CW, the IC 7300 is set to CW-R! Why is the radio set in the reverse CW mode?
Thanks!
Bert VE3NR
Re: Double clicking on cluster spot puts IC7300 in CW-R mode
ve3nr wrote: 16 Oct 2023, 17:34 When double clicking on a cluster spot, spotted stn working CW, the IC 7300 is set to CW-R! Why is the radio set in the reverse CW mode?
Thanks!
Bert VE3NR
Bert,
Check the options available to select at Configuration / CAT. As I recall one of them addresses that, but I can't be sure. I don't have an IC rig to test with.
Is your software/firmware for the IC 7300 current?
ve3nr
Post by ve3nr »
Hi Nolan,
Thanks for your reply. I'm using current firmware for the IC7300. Checking off the option "Reverse side SSB (CW)" fixes the problem, but it seems backwards. It should NOT reverse CW if I don't check off that option!!?? Now it's the other way around. Maybe I missed something?
Thanks again.
73 Bert VE3NR
